? it doesJust noticed that the actual wiring doesn’t quite match the Tekken 6 manual wiring diagram. No problem on the side, if it goes player 2 side I will just switch it over.
Thanks again.
That's correct its a serial connection between the two devicesIf you follow the red wire, according to the Tekken 6 schematic P1_TXD goes from pin 3 on the card reader and then goes to pin 1 on the header which is labelled P1_RXD. P1_TXD is pin 3 on the header so something has gone a miss on the labelling. I trust the photographs of the wiring and not the manual labelling.
