try the 120s if you've got them.The chips I used for 26-29 do look kind of suspicious now that you mention it. Unfortunately the rest of the ones I have of that size are 150ns or 120ns.
yes, that's it! ... so do you think BBB only works with this stuff removed?![]()
I found a pic of the BBB with mobo and see what you mean, it's missing some chips in that section
hmm all of my MS32 stuff is in storage but I don't think any of my boards are missing those chips. I distinctively remember comparing mobos side by side trying to work out what was different to make one work and the other not, and aside from a few small capacitors bridged across pins on a couple of chips I didn't see anything, I certainly don't recall any missing chips.yes, that's it! ... so do you think BBB only works with this stuff removed?
Yeah. It goes past that to this screen. It almost looks like something is going on underneath the static. I'll check out redoing 10 and 11 a little later today.does it get past that screen? if so it seems to imply that at least the program ROMs are correct now... probably has some issues with the txt ROMs which I think are 10 and 11
made this mistake and i confirm any JMS32 cartridge will work only if you insert in the correct orientationUnfortunately, jumpers did not fix it.
Did you know that the connectors on the ROM board don't stop you from putting it on upside-down? And also that even though when the game is in the case, you orient the text with the bottom facing away from the JAMMA edge, if you don't have the case on because you're trying to get a conversion to work, the text printed on the board should be oriented the other way with the bottom facing toward the JAMMA edge? This knowledge did not fix the problem either, but it was certainly a good thing to figure out.
I tried putting the Game Tengoku ROMs back on just to make sure there wasn't an issue with the ROM board and everything booted up just fine. There must be something else I'm missing. Assuming this particular conversion works at all, I suppose.
That to me looks like what you get when you're using the wrong data encryption for the security chip.Yeah. It goes past that to this screen. It almost looks like something is going on underneath the static. I'll check out redoing 10 and 11 a little later today.
no, just validate that the data is correct and that they're installed in the right slotSo do I need decrypted ROMs? Or do I just need to try redoing those?
