plasticfactory
If it will a) fit a Life Force board, and b) I can get it without the handle, I'm in for one, maybe two.
HI! Yes, Life Force I think is compatible. For scruple, send me the precise measurements privately.If it will a) fit a Life Force board, and b) I can get it without the handle, I'm in for one, maybe two.
Sure! Yes, I create the artwork every time.Awesome! I'm for sure in for 2, maybe 3. The other boards would be Gradius 2 and V-V.
Will you be creating the artwork for these on an individual basis?
No problem! Perfect fitHow about Namco System 2, or Irem M72?
Those are big beasts.
Don't worry, I can make it without the handle! It's the same, just delete that part.Not to make your life a pain in the ass or anything but could that be a standard option? I'm not totally sold on the handle myself. Got any pics of it without?
Most likely wherever the boards region is from. So Western for Life Force, and most likely Japan for Gradius 2.Sure! Yes, I create the artwork every time.
Indeed, I wanted to ask you, do you want the names of the jap versions or those with western names?
PERFECT!Most likely wherever the boards region is from. So Western for Life Force, and most likely Japan for Gradius 2.
HI! thanks for your questions.Is it possible to change the pcb plastic fixed leg to a strong fixed leg in the configuration of this product?
Fixed plates seem to use regular mdf wood material, isn't it vulnerable to moisture? I think it might be some aggressive conversation but I'm trying to keep some of them safe because I have expensive substrates too. Then I'm looking for a case and I have a lot of questions from the introduction video. I hope you don't misunderstand.
Are you able to adapt the Sega System 16 design into this? Including the Sega vent cutout? Might be able to move the 3 people currently trying to reserve one to this model to get it closer to the 12 requirement. I am down for this model if it's possible. (edit: I'll DM you cause I can't read the big red letters to DM you questions...lol)There are 5 cases left to start production.
For any questions, write me in private!
