I hope you good people can help me out with a bizarre issue I have with the Rev.2 kit.
Background:
I purchased a built to order Consolised CPS2 in November that was working near perfectly, however, there were the odd issues with jailbars when flashing certain games that was driving me crazy. I opened up the B Board to use contact cleaner to clean the contacts, tested and the situation slightly improved. Getting a little too confident I took the entire kit out to reseat it and bent one of the pins on the fingerboard, which I later snapped when trying to straighten it. Anyhow, having average soldering skills I decided to purchase another kit and have the first one repaired and sold on in longer time.
Problem:
The new kit arrived and I removed the old kit (which incidentally had key wires installed for encrypted games) and installed without wires. I downloaded the old decrypted rom pack, but it failed to load and went to the yellow/brown screen which usually suggests a suicided board. I removed and re-seated everything again, ensuring the bridge adapter had J1 going into the top board with the SD Card and J2 into the sub-board - as per instructions on here. I shorted the EXC5 and still the problem persists.
The Strange Part...
The only rom and key that works in the 'encrypted' 1944 The Loop Master - considering the key wires are no longer in place for encrypted games?! Flashing any other rom (encrypted or decrypted) keeps the system on the yellow/brown screen. It should be noted that whilst 1944 works, it displays patterned glitches, and when flashing a new game the image looks like a bad VHS tape with the tracking out. I have inspected all pins on the A/B Boards and the rom sockets for issues.
I would really appreciate some help. Thanks in advance
Background:
Problem:
The Strange Part...
