freddiefiasco
I just got to wondering this given Mitsurugi-w has this fixed version of F-Zero. Shot in the dark but if the motor uses the MIDI board, it sounds promising.The wiring diagram shows it using the Sega MIDI board, not the Namco one, I believe:http://wiki.arcadeotaku.com/images/6/6d/FZeroSTDWiring.pdfCan F-Zero be set up in a way to use FFB from other NAOMI 2 games or does it only work with the NAMCO FFB?Most games allow you to turn off the FFB to boot the game without but F-Zero will not boot if the motor initialization test fails. You can't turn it off either. That's why this change was made so that we could play the game without a full cabinet.
Interesting... I wonder how compatible this game would be in an ID/OR2 cab.
