If it's the bios that the problem then why is it that some of us are able to use the Rev H bios without problems?As plasia posted in his first post and I already anticipated, the problem is the BIOS.
What is your setup? Are you netbooting or CF?If it's the bios that the problem then why is it that some of us are able to use the Rev H bios without problems?As plasia posted in his first post and I already anticipated, the problem is the BIOS.
I've used both NAOMI 1 with Rev H multibios (the one on arcade otaku) and NOAMI 2 with Rev C multi bios. I've run both with rev 4.02 net-dimm and 3.17 net dimm with pi-force tools ver 1.2 using Atomiswave roms from neoarcadia.What is your setup? Are you netbooting or CF?If it's the bios that the problem then why is it that some of us are able to use the Rev H bios without problems?As plasia posted in his first post and I already anticipated, the problem is the BIOS.
is it known, problems happens with both regular Rev.H and multibios Rev.H or with multibios only?My guess is that differences between G and H are minor. Different BIOS can have a significant delay and therefore not work.
Multibios only thus far. Seems to be intermittent too. Some people have issues, others do not.is it known, problems happens with both regular Rev.H and multibios Rev.H or with multibios only?
I got my multibios from Mitsurugi. If there are two versions, I am not sure which one he burned. That is if there are two versions of the multibios. Personally, I was only aware of one.could be wrong but isn't there 2 multi bioses going around one is just a multi bios and one allows the 2in1 to work. Which could explain why one multi works and the other doesn't
Then please share your knowledge with the rest of the members pleaseI'm sticking with epr-21578g not a black screen yet. I got making cf cards down to a science now...various brands/sizes of compact flash cards,none has failed since i figured it all out.
Good info. Let's see what can tell us the rest of people with issues.In regards to the atomiswave conversions, I did some more testing with NAOMI 1. I am still actually unable to reproduce the black screen issue across 4 different N1 motherboards and 3 different dimm boards.
I thought that perhaps USA region on dip2 caused issues, but I was unable to confirm that. I just netbooted GGX1.5 on both the JP and US regions of the multi.
So far, the only black screen I've been seen with an AW game is on the NAOMI 2 with multi bios.
