TTX3 multi player assignment issue
notsofried
Bay Area
Been trying to solve this in various ways with no luck. Thanks for any help!
Setup:
- Vewlix Diamond Orange with original wiring removed
- TTX3 with Artax multi 4.1
- Two GP2040-CE boards with the latest firmware (also tried brook retro boards with similar results)
When I power on, most of the time (~90%), the 2P joystick will control the menu to select a game. But once any game is loaded, the P1 and P2 assignment is correct.
The other 10% though, the P1 joystick has control over the game menu. When this occurs I might as well reboot because once any game is loaded, the player assignment is reversed in the game. If I unplug the 2nd player USB and let it get assigned correctly to P1 and then reconnect it, it works correctly when going back into the next game. But once you exit back to the menu it will revert to being messed up again.
I've tried a combination of using different USB ports to see if it would help and it doesn't. I saw a similar issue was reported as the 3rd point in this post, and the solution below that was to create a few scripts that force the order that they're enabled and disabled. I'll look into that more but wanted to ask first in case there's a setting somewhere that would help.
