MoppelTheWhale
Hi guys,
a few days ago i got my st-v board and Winter Heat, just in time for my multi which should hopefully arrive soon. In the beginning it scared me a bit because it always stopped working. It turned out the voltage was to low, with 5,05v it works flawless
But now i have a few questions.
1.) The st-v board has a battery holder, but atm no battery in it. What battery do i need and what is it for? while testing everything seemed to work fine, it even seemed to keep the high scores between (short) power off periods.
2.) I want to play both Radiant Silvergun with three Button Layout and Die Hard Arcade, so i think I need a Multibios or at least a japanese bios to swap out... I don't want to swap chips all the time, so Modbios it is
. Where is the proper place to buy one (i more or less only found arcademodbios or ebay...) and on arcademodbios they want to know which bios type of ic8 i have.
I don't have a clue what that means (IC8 means it is the chip on chip position 8 i think), the chip there is completely covered by a big blank sticker, do i have to remove that to see andy markings?
3.) The last question is about my Neo Geo MV1FZ board. The battery look good for me and i'm not sure if i should swap it. I read something about using a Supercap instead. WHen i take the Supercap Route i keep the charging mechanism, when i plan to use a normal battery i have to remove the charging...
Sorry for the noobish questions, i just don't want to destroy my stuff
Cheers and thanks for your help!
