umk3 problems
For the missing color, are you sure the board is fully working? Missing a color like blue or red is a common failure. First thing I would do first is completely clean the jamma edge to make sure it's making good contact, the wolf units flex quite a bit and I've had a loss of color just from a dirty board.
what is the name of the connector into the kick harness? i would like to make some clean connection if possible, instead of just soldering the wires directly to the motherboard.
The factory uses Molex .156 IDC connectors. They're actually really difficult to come by. in the past I've just bought used harnesses and re-purposed the connectors.
I highly recommend the JNX Raiden adapter/kick consolidator (with H1 harness)...
GOOD! because IDC are CRAP! you look at them and a wire will come out.... and while you try to fix it, 3 more come out. They were used because they are a way to cheaply build harnesses!
We throw them away in pinball and replace them with proper connectors! and seriously, I have a box full of pinball harnesses...
for a really good page on connectors, crimps and pins, here you go: http://www.pinrepair.com/connect/
it's true. I've had to fix bad wire-to-pin contact in these connectors on both my UMK3 and my KI2 cabs.
