hardyhell
how is the Monitor of the second cab powered?
my psu in the new astro cities only work fine when they have a certain load
sounds great thanks.Some power supplies shut off without load, but often those only concern the DC power supplies which would power a JAMMA game, and not the AC part, which is more or less just passed through.
The JAMMA pins for the power are there on my P2 board, so it wouldn't be hard to bodge solder in a load resistor if deemed necessary.
Any thoughts on this?@Hatsune Mike
Have you considered getting this to support a 4 player multiplayer set-up? Being able to toggle between P1 vs P2, to propagating P3 and P4 on Cabinet 2's P1 and P2 instead?
Clearly you built this for a versus fighter set-up, but with a bit more re-routing work, and perhaps some clever jumpers, could this be a feature for this as well?
Having a plug-n-play solution for versus setups in indeed handy, but it would also be great if we can have an easy solution like this for 4 player 2 cabinet set-ups. Thoughts?
Sorry, I'm not really interested in doing a 4P harness any time soon. One big issue with them is that I'm not sure the input system is particularly standardized for them. It'd also be a near doubling of the amount of cabling. It can not be done with just some simple extra routing and jumpers. I'd have to return to an older idea I had, which was to do some multiplexing logic on the P2 side (the earliest iteration of this versus kit used one 10p10c connector, but poor grounding made me abandon that idea).Any thoughts on this?@Hatsune Mike
It's honestly a separate thought, that should really be addressed by a separate product (from someone who has an interest or passion in the idea).Sorry, I'm not really interested in doing a 4P harness any time soon.
NAC Splitfire: JAMMA streaming solutionLooks really nice.
If you could add a scart connector to the 2nd cabinet PCb, for streaming purposes that be even more awesome.
Do you already have an idea what they will cost?
You can put me on the waiting list for one of those.![]()
It would also add unnecessary expense and assembly time for everyone just looking to link some cabs. Every linked cab doesn't need to be streamed.But having it all in One connector would be better instead of having a adpator centipede on the boards.
