MisterRadon
Hello everyone, new to the forums but this is a resource I could definitely see myself using many times in the future. I just purchased a Konami Dance Maniax (System 573 digital) cabinet and when it arrived, the machine booted properly but the P1 start, service button, and coin mech are all not responding. Other buttons may not be working as well (though the P1 left/right arrows, test mode button, and degauss button are all working), but with no way to navigate the test menu or coin the machine up, I haven't been able to test them easily. I know these are all next to each other on pins 15-17 of the jamma, and I've asked a couple of people who have suggested that the issue is either the ground wiring, the jamma harness itself, or that it could be a power issue. Roughly 10% of the time I turn the game on, the machine will restart itself repeatedly on powerup with a clicking sound and the monitor clearly turning on and off repeatedly, and according to an article I read on gamerepair this is probably due to a bad power supply. So I figured the power supply would be the most likely culprit and the easiest to check. I took it out of the machine only to not see any adjustable components on the power supply, and it appears to be a rather bulky unit that I'm not familiar with.
So as someone who knows his way around the inside of an arcade machine but is completely a novice to repairs of this nature, what should I be looking to do? Should I narrow down my other options first? Is there a way to make sure the correct voltage is being supplied? And if there isn't, how would I go about tracking down a replacement power supply? The same article suggested that a replacement could be wired in using a standard AT/ATX power supply by bridging the sense wires, but to be frank I don't know what that means much less how to do it.
Thanks for having me and for any help you can provide!
