kspiff
So I elected to just replace all the electrolytic caps on the used FC I bought before I power it up.
Going through the monitor PCBs, I'm noticing that R1 on what appears to be a power PCB (PAP-04B) from the monitor is crispy.
Unfortunately, while I could make out "...02" on the resistor, I'm not sure of the value. I could assume it is "102" which means 1kohm 5%, but currently the thing reads 982ohm. Would assume it would fail open, or be over 1kohm if burned.
I don't suppose schematics exist for these monitors?
I'd ask if anyone could do an ID, but the board is under EMI foil tape.
