FOUND Vewlix Marquee Light Assembly
Item has been found
aimbuster
California
Looking for an original Vewlix marquee light assembly. I do not need the marquee acrylic holder. Just the light assembly inside the marquee.
If you have one for sale, let me know!
Technically, you just need the PCB, short wiring harness and the mounting plate (right?). All the other parts are already there.
Those PCBs came with every F and FC.
Honestly, if you're into DIY, the thing is nothing more than a LED bar. You could buy a simple strip for around $10, crimp the correct connector to it and 3D print some mounting brackets.
I have an unlit L, I might look into this over the weekend.
I already have a DYI LED strip installed. Basic LED strip actually looking pretty good. But I still want to get this original Taito light assembly.
Basically I just need the Light PCB. There are already screw mounts for it in the marquee frame.
Reactions: nem
