After looking and failing to buy some Vewlix sub panels I'm looking to get some made. I've been talking to Olly @ ArcadeArtShop and he's happy to work on them with me, we just need to decide what features/controls are needed. It's probably going to be subjective what's required but it would be nice if we could come up with a design or two that would cater for most peoples needs.
I'm pretty new to the Vewlix and using multiple consoles on them, especially PS3/PS4/XB1 one which I don't have so I could do with some input.
I'm thinking....
Volume control: Most solutions seem to use a A/B50K pot so a 7mm hole should suffice. Room on the panel for a ~30mm knob.
Headphone jack: Personal preference this one, I want a headphone jack which cuts the cab audio when the headphones are inserted. I've hacked something together and tested this using a 1/4" DPDT jack and it works well so far. I'm just waiting on the pots to arrive to wire up and test the remaining parts.
Rocker switches: I'm using Brook UFBs in mine so I'm thinking of using rocker switches to cut power to the Brooks when changing systems, a'la [this] video. I'm planning on using some nicer round blue/black/white switches for mine. Is there a better solution for this?
USB ports: I've seen 2x USB ports in some panels. Are these necessary? What do people use them for, additional controllers? I can't see why you would use them for cab management. Do people use these at all? I can't see myself using them personally but they could be added to a panel type if there was demand.
Buttons: Now, this is the big one. Most panels I have seen have SHARE | HOME | TOUCHPAD for both players. Are all of these strictly necessary for both players?
From my understanding:
SHARE - Looks to be Select/Back for most systems - and 'Share' for PS4
HOME - Home for all systems.
TOUCHPAD - From what I've read this has limited use for PS4 and is some times used for Pause/Back in a few games.
Personally, I would be happy with 'SHARE' and 'HOME' but I would be happy to add 'TOUCHPAD' too if its useful. Do they really need to be duplicated for both players though?
Any other thoughts on what you might want, or not want on a sub panel?
I've got the panel drawn up in NX, I'll add some pictures etc as development continues...
I'm thinking....
