jonsilvestro
Hey folks, I've got a Sanwa PFX out of a Wangan Midnight 3 I'm having some issues with and I'm frankly at a loss for what to try next.
The chassis is a Weiya C3129D with a Beijing-Matsushita a68mau085x90 and I believe the original PFX yoke.
I've already recapped the whole chassis, I replaced the vertical deflection IC, I tested and replaced most of the passive components in the vertical deflection circuit, I reflowed most of the solder joints and tested them for at least continuity and I pulled the yoke to check for any corrosion, while I don't have an LCR meter to properly check the yoke I don't think its causing the issue.
What you see is all I've managed to get and it hasn't changed at all with any of those things I mentioned doing.
At this point I don't know what else to try, I don't have another tube, yoke or chassis on hand to test (with the exception of another C3129D that has a different chassis revision and I know is dead) I am trying to source something so I can at least narrow the problem down some though.
Has anyone else had a similar issue? Anyone else running the same chassis yoke and tube setup?
Any new ideas would be very welcomed and I'd be happy to provide any more information anyone thinks is pertinent and helpful to diagnose it.
Thanks!
Thanks!
