MagicianLord77
Hi Guys,
I've got this chassis + monitor combo from a Pinball 2000 machine, when taken out from the pinball cabinet it was all loose and falling apart. I mean chassis half-disconnected, yoke and convergence rings were loose, very loose
. The pinball has an LCD monitor now so it doesn't need this monitor.
Now I'm checking the items I have and trying to think about the possibilities, I'd like to make this monitor work to have it as a test monitor or to repair another cabinet or whatever. So, here are the items:
The tube is a Samsung 5108B22 and it has burn marks of "pocket gal". I know that the WG chassis is the original Pin2000 one, but does somebody know if this tube could be the one that came with the chassis? I guess it was swapped?
The questions are:
- Do you think this chassis + monitor combination would work? (don't even know if it was powered on in the past)
- Can I try assembling everything and powering on the chassis to see what happens?
- If it powers on, how hard would be to get the yoke and convergence rings aligned for a decent picture?, do you think it would be worth the effort?
Thanks
The questions are:
Thanks
