J
jassin000
15khz still looks pretty good to me!
that board looks quite useful for a supergun setup or if you just want to replace a damaged monitor with a LED/LCD screen.They do not scale, the monitors actually behave allot like a large PC gaming LCD (think BenQ and Asus).
Officially Taito supports 15khz (JAMMA) video with a separate scaler board that installs inside the bottom of the Vewlix as part of the JAMMA kit.
I did my best to provide a high rez image of the scaler PCB in my Vewlix thread.
If it's an HDCP issue (most likely because wiiu/pc worked) you can get around this buy getting a cheap HDMI splitter: http://amzn.to/1U98u3lThanks Jassin that is good to know..
Rather then spending money on something like that why don't you go ahead and switch HDCP off through the PS4 menu..If it's an HDCP issue (most likely because wiiu/pc worked) you can get around this buy getting a cheap HDMI splitter: http://amzn.to/1U98u3lThanks Jassin that is good to know..
A lot of these cheap chinese splitters don't conform to hdcp standards and will completely ignore HDCP protection. I've been using this to connect my PS3 to my capture card without problems, and it should work for you too.
Yes that works with PS4 thankfully... But you know what it won't work on? PS3!I can report that DHCP off did the trick![]()
I had no idea you could just turn it off on PS4 (I don't own one yetYes that works with PS4 thankfully... But you know what it won't work on? PS3!Turns out the way they wrote the DHCP enforcement on PS3 makes it part of the Hypervisor (onboard chip function) that can't be disabled.I can report that DHCP off did the trick![]()
Do you notice any lag? I feel like doing the same setup type.New wiring with brooks universal fighting board.
