What power supply for arcade supergun?
Hi, for a supergun or arcade games, it's better if you can adjust your 5v.
Meanwell rt85 or rt125, really good power supplies and 5v adjust ;)
Maybe you will have to wire it but it's not complicated, you don't use 24 wire but only 3 or 5/6 if it's doubled (2 for 5v, 2 for 12v and 2 grounds).
ive heard good things about meanwell seen a few on ebay in the past, i'll look into that, i'll check ebay for these power supply, much appreciated for your advice bro
Does it matter if it's an RT-85 or an RT-85A/B/C etc?
Thanks for the confirmation! :)
Sorry I wrote that quick on my way to work, so I didn't get to elaborate, but the A has a -5v line which you need for audio for many arcade PCBs. Also, A has more amps on the 5/12v lines, vice the B and the C, which also help with larger arcade PCBs. Also the 65A works for most, the 85A for almost all, and the 125A for them all, if you don't mind the slightly longer length, go for the 125A!
Short version: A for Arcade!
