D
Deleted-6003
Windygaming offers it, but it's out of stock and ebay only has one from Canada for about $40. Any other place I could it from? Maybe building one myself?
Any tutorial or documentation on how to make one?yaj has used ones sometimes. you can just make it yourself for less than they charge to buy one... but your time is worth something too. best bet is to get a used panel that includes all of the harnesses.
Don't forget though, if you use the aux button input in the control panel, you need a matching output one for down inside the cab next to the JAMMA connector. so you will probably have to build that regardless. maybe Lemony or someone sells an astro to cps2 already wired up?
Sorry for being so indecisive, but I think I'll just buy one from YAJ. Do you have a link to his page? I couldn't find his profile.this should get you started:
https://wiki.arcadeotaku.com/w/Sega_Blast_City_Wiring_Guide
https://wiki.arcadeotaku.com/w/Kick_Harness#CPS2.2FCPS3_-_2_Player_Harness
you essentially just make a ground wire with several connectors on it to hook up to the extra buttons. then run one signal wire to each button. inside the cab you have to do the reverse pinout to cps2 connector.
YAJ is Yahoo Auctions Japan... Basically their eBay. hate to send you down a rabbit hole, but prepare yourself. Find yourself a good proxy and learn how to translate what you're looking for. Good luck.Sorry for being so indecisive, but I think I'll just buy one from YAJ. Do you have a link to his page? I couldn't find his profile.
I have the same crimping tool, it works well. Just put the quick-connect into the appropriate hole, click down a couple times, the tool will hold the quick-connect in-place, insert your wire, crimp down, good to go. =)Nice, thanks! The jlf sticks I ordered came with the connectors so I hadn’t thought about adding that. Apparently I need to learn how to use the crimping tool because it isn’t super straightforward.
