Where to connect this new net city cable
Adrick
León Spain
Hello I am restoring my new net city to leave it with the original jvs, the previous owner made a jamma comb, I was removing it but I have a problem I am seeing a colored cable that comes from the chassis, where is the VGA connection there are two molex, the left molex I have identified is connected to the power supply, but the right molex is the problem is spliced to the central area of the comb jamma I guess to send video signal, my question is where is originally connected that cable to the machine, I leave some photos I hope someone helps me because I'm stuck.
What I intend to do is to unpack it from the jamma comb and connect it its place of origin.
the circled picture is the coloured wire that is connected to the central area of the jamma comb.
My nnc has jamma connected directly to that socket and Naomi to the jamma comb so I have jamma+Capcom io+Naomi or jvs and Naomi. But I don't know where on the machine I am supposed to connect the red, green, blue, white and black wires to when I remove them from the jamma comb, they can't be tucked away because they are supposed to have some connection socket and I don't know where to connect them.
[media]
According to this YouTube user they go to the amplifier, two wires red and black, which puts image and sound out there ???
[/quote]
Hi, apparently I don't see anything but those wires coming out of the connector so I don't know what to do with them.
In that socket nothing is connected ?
Greetings Adri. 😊🙏
Assuming it's the same as my NNC, the chassis has two video inputs. You can just leave that disconnected if you're removing all of the jamma wiring. JVS games use the VGA cable for video.
Asumiendo que es lo mismo que mi NNC, el chasis tiene dos entradas de video. Puede dejarlo desconectado si está quitando todo el cableado jamma. Los juegos JVS usan el cable VGA para video.
Thank you very much, I thought the degaussing cable was connected there un the chasis, although on my nnc the degaussing cable is in the jvs and control area and goes under the monitor finished in to the right side of the machine leg and from there to the back. I think it works perfectly on both jamma and jvs, the secondary video cable must not have some kind of secondary connector or is it unplugged?
Sorry, I don't speak Spanish. Your question might be lost in Google translation.
If you're asking about the degauss button, my monitor is the Toshiba D29C051. The degauss button is digital and part of the remote board.
Oh sorry, I didn't realise I wrote in my native language, I edited the English message above.
