We are also on the market with our new Bazooka Supergun...
www.beharbros.com/product-page/bazooka-arcade-supergun
Features
- Impedance-matched, amplified RGB video output powered by the renowned **THS7374 video amplifier IC**.
- Individual potentiometers for precise RGB color-level calibration.
- Built-in low-pass filter with selectable ON/OFF functionality.
- Euro SCART connector for RGB video and stereo audio output.
- Two selectable sync modes via jumper: attenuated and buffered sync through the THS7374, or Schmitt trigger-based sync.
- Designed to work safely with video upscalers.
- Advanced audio attenuation circuit featuring two 1:1 isolation transformers and a separate audio ground for improved audio isolation.
- 3.5 mm stereo line-level audio input.
- Selectable audio source: attenuated arcade audio or stereo Line In.
- Stereo/Mono switch.
- Two Saturn controller ports with all six buttons fully wired.
- Compatible with CPS, Atomiswave, and CHAMMA-based boards, including Pandora systems.
- Dedicated Kick Harness connector.
- DIP switch for selecting whether buttons 4, 5, and 6 are handled through the JAMMA connector or Kick Harness.
- Seven selectable presets for different button layouts.
- Three selectable auto-fire modes(low-medium-high), available for all controller buttons.
- Built-in LCD voltmeter for monitoring the 5V input.
- Dedicated Test, Service, and Coin 1 push-buttons.
- Blue power indicator LED.
1. **Custom Power Cable
* High-quality cable featuring a 6-pin Mini-Fit Jr. connector, wired for 2× GND, 2× +5V, 1× +12V, and 1× -5V.
2. **Custom Kick Harness
* Specifically made for CPS2 and CPS3 arcade boards.
3. **Custom Plexiglass Enclosure
* Beautifully crafted from 3 mm orange transparent plexiglass, featuring a custom laser-etched design.
