His "CHD Extraction and Conversion Guide" sticky;
Specifically
STEP 8 – BONUS TRACK
It's possible to reenctypt a game in order to use with another NON-ZeroKey Security Chip different from the
one it was intended for. You just need to decrypt the game with the game key and reencrypt the game again
with the NEW KEY of the Security Chip that you intend to use.
For NetBooting is trivial. You can use GDRom Explorer to decrypt the game and then encrypt it again using
this little tool (Crappy slow beta version, but works).
For Compact Flash, you also need to make sure that the filename of the first file to load, matches both in the
PIC and in the Compact Flash. In the previous example, I didn't change the name of the file but if you want to
use it with a NonZerokey chip, we need to change it to make it match with the one on the new pic The
location of the filename can be found on the PIC and can be seen in the picture 9 which is BDV.BIN.
Looking for that tool (or something that can reencrypt) so I can use a non-zerokey...
Thx!
