FOUND Working Sanwa Chassis
Item has been found
kikaso
Enlightened
New York City
Sanwa PM1723D
Toshiba 470MSB22 18” tube
(or equivalent)
Looking for a backup for the Mini Cute
Not sure what these go for so let's talk. :unsure:
I have a line on a burn free 18" tube. Chassis is out getting capped/repaired- I'll have to check what model it is- it's either Toei or Sanwa.. What are you planning on using it in? Most of the 18" tubes will fit in the same thing- you'd just need to change the RGB connector if it's not the same model (sometimes)
I still have the extra Sanwa 18”.. You should have let me know back then that you also wanted that..
I have the Toshiba 470MSB22 18" tube and the Sanwa PM1723E chassis.In this case, I have the Capcom Mini Cute that came with the original tube; only the chassis is different, but it works normally with some screen interference.
Searching on Yahoo! Auctions, I found the Sanwa PM1723E chassis, as I saw on the internet that it is the original chassis for the Capcom Mini Cute.
When it arrived, I encountered a detail: I couldn't install the chassis on the tube.
In my case, where I connect that small board, the tube has 10 pins, and the board on the chassis only has slots for 8 pins. I'm only unsure about this fact.
Can anyone tell me if there are different versions of this chassis?
Another question, I would like to see the connection of these wires. I don't have this 6-pin connector; I just want to confirm the wire connections.
It's a different neck board (with a different neck connector). The chassis is more than likely the same.
Researching extensively on the internet, I saw that there are different versions of this chassis. In my case, it's version E. There are versions C and D. These versions come with the correct neckboard for the Toshiba 470MSB22 18" tube. I'm attaching a photo of the neckboard from the Sanwa PM1723C chassis.
I'm pretty sure you can swap the neck board between different revisions. Functionally they should be the same.
