Here is my custom made cabinet for the CPS2 Multikit, including te proper artwork
https://www.youtube.com/watch?v=6Xz59H-RPx0
It doesn't get better than that. Those candies look mint.Multi CPS1 on the NNC & Multi CPS2 on the NAC![]()
I can, but the problem with doing that is the way the Vewlix is made.I bet you could hook up the stereo jacks to the 'lix for that sweet qsound audio though right?
I bet that was a tight fit.She needs a cleaning, but here's my CPS2 multi setup!
Thanks man!Opt2not: I love the way your redux sticker turned out, I also really like the yellow color shell and matching LCD holder.
Not sure how the Viewlix cabinet works, but have you thought about doing what I've done in the image below? I took the speaker positive and negative signal from the Jamma Harness and routed it to the input of a Line Output Conditioner to "de-amplify" the signal. I then used a Y splitter an hooked one end up to one of the outputs channels of the LOC, then the two opposite ends are plugged into the audio amp in the left/right channel.I can, but the problem with doing that is the way the Vewlix is made.If the speakers are connected to the RCA amp the JAMMA edge can not be.If the JAMMA edge is connected to the speakers the amp can not be.To switch the connection you need to remove the lower back panel and move the mini molex jr head.It's a simply swap, that takes waaaay longer than it should because of the way you need to access it.To make it easy on myself I just leave the JAMMA edge hooked up at all times.As boards that support RCA audio always have the option to use the edge as well, but not every JAMMA board supports RCA audio.I bet you could hook up the stereo jacks to the 'lix for that sweet qsound audio though right?
Dat NEOGEO
Giant pix!
Sorry lol, I posted this from my phone. I'm back on my desktop.Just a helpful photo hosting tip (that I just learned last night)
