Alrighty. Got some blast city cabs a while back that are wired for jamma. They work fine with standard res stuff but I want to try Naomi on them. I don’t see any switches anywhere so I’m assuming just connect db15 if I want to use that and disconnect it if I want to use a standard res board? I see this little board on the monitor board with what looks like db15, can’t see the edge. So should I just be fine connecting a vga cable here then to Naomi? I have a Capcom I/o. I think I did test running the Naomi at 15hz a long time ago but of course I’d rather run this at 31hz.
edit: so apparently sometimes connecting a standard vga cable to certain monitors can cause issues and maybe ruin your Naomi. The original cable has no pin 9 on either side. Anyway I’m modifying a cable before I try this again.
