jcmorrisii
These are Arcade Control Panel Wall Mount Brackets! I've meticulously engineered them to fit most Japanese control panels with plenty of clearance for all components. This includes them hosting 1 or 2 levers, and all button configurations, while still displaying the panel at a proper viewing angle. Tried, tested, and true.
Intended use is display on walls while not in use on respective cabinets.
Fits different size and layout variants with plenty of clearance, regardless of number of buttons and levers.
No longer have to worry about depopulating and repopulating panels each time you want to switch them out.
Can also be used on a flat work surface if you prefer to display your CP on a desk. (Rubber Feet included)
Makes wiring a control panel a breeze, allowing you access to either side while installing levers, buttons and wiring.
The standard bracket is printed in Black Gloss or White Matte PLA. You can also order a custom color of your choosing or have them printed in PETG for high temps! Please contact me and I can work with you to provide an exact match. Because each control panel requires 2 brackets to hold it up, these are sold in sets of 2 with mounting hardware included as well as rubber feet for desks. The mounting hardware can be used in Drywall, wood, or brick/stone. (See photos). I ship same day if ordered before 3PM EST.
Use the code "TAITO" for $5 off, or contact me directly here so I don't have to pay Etsy 6%
Links:
Humbler Tools on Etsy
Twitter
Links:
