Seriously? Please read the instructions. That C board is strongly modified and won't allow for key writing.I bought 2 of these C boards from China. Chip looks modded- might this be the cause of the problems?
Only 2 left!!@RickyTTT was selling some that are very good quality. You can find also some on eBay.
So I tried the multi with the audio being pulled from CN5. It works but the down side is you can't have the audio plugged in to both CN5 and the rca jacks for Q-Sound games at the same time, otherwise you'll get no audio from either source. I'm hopeful that plugging both outputs into a switcher will solve the problem.I havent tried that, and I wont have time in a few weeks, so I cant say if it's safe or not.
That’s really interesting! I wish Capcom just sent at least some version of mono to the Qsound output for non cps1.5 games. I could live with only right for cps1 and then stereo for cps1.5 lol.So I tried the multi with the audio being pulled from CN5. It works but the down side is you can't have the audio plugged in to both CN5 and the rca jacks for Q-Sound games at the same time, otherwise you'll get no audio from either source. I'm hopeful that plugging both outputs into a switcher will solve the problem.
There is no q-sound on non-cps1.5 games.That’s really interesting! I wish Capcom just sent at least some version of mono to the Qsound output for non cps1.5 games. I could live with only right for cps1 and then stereo for cps1.5 lol.
Yes@RickyTTT was selling some that are very good quality. You can find also some on eBay.
Search archive.org.Yesi bought one to RickyTT.thx to him.
i have my dash board and C board as well but
Did I miss something ? I don’t find any link for DL the rollerpack ? No roller pack anymore ?
Hello, I have been testing out my CPS1 multi and I thought it was working great, but now that I've finally tested a 6 button game I've run into a big problem. When playing SF2 (version doesn't matter), buttons 4 and 5 are currently not working for player one. Player one button 6 (as well as all player 2 buttons) work fine. Just to test out other components, I even swapped it with a different donor pcb, but no matter what I try, those two buttons don't work. When I used the same boards/cables with my friends multi instead, the buttons worked, so it seems to be an issue with my multi board itself. Please advise!
PM sentOnly 2 left!!
You should first follow DarkSoft's advice regarding the C board and on-off switch.Hello.
It is not the harness/setup, as replacing just the multi board with my friends multi board (but keeping every single other piece intact including the same kick harness) resulted in the buttons working.
Other than connecting the kick harness, I'm not sure how to test "directly" as you mentioned. I'm not the best at this stuff, but I thought what I did before eliminated the other potential variables.
Thanks for the help! And yes...I too am glad the kiddo is safe.![]()
Yes, the same A board, C board (92641C-1), and kick harness was used.... and the on/off switch was not touched at all (it is in the ON position). Using only a different B board my friend also purchased from you, everything worked perfectly.Are you using the same C board on both cases? And the switch ON/OFF is in both cases on the same position?
OK, maybe there is something wrong with your kit. Please PM me and we'll sort it out.Yes, the same A board, C board (92641C-1), and kick harness was used.... and the on/off switch was not touched at all (it is in the ON position). Using only a different B board my friend also purchased from you, everything worked perfectly.
