gmoneyfivetwenty
Tucson
My CPS3 has a burnt resistor K DA4. The game will start sometimes but quickly faults and some times it wont start at all. Does anyone repair these systems? Thank You
Pics of the repair in case that link doesn't work for some.
It was supposed to be a burnt resistor which in reality turned out to be a switching diode. I took it from a parts board, but upon visual inspection I found bent pins on the ppu. Some were touching and loose. I straightened and reflowed as best as I could.
I took some direct captures of the game that was already programmed there 2nd impact after the fix, then I programmed 3S just to test further.
Ok case installed.
