Hello everyone,
I recently acquired a capcom cps3 with 3rd strike working. I am wanting to make a somewhat portable supergun setup to bring to tournaments and I just had a few questions before I take the plunge and buy all the parts.
I build synthesisers so I'm pretty good with electronics and soldering but I don't know too much about arcade hardware.
My plan so far is to get a Windy Gaming ATP-300 supergun and a pair of the undamned usb to db25 encoders (including the necessary windy gaming undamned thingies that lets you use the encoders on an atp-300) so people with a usb arcade stick can use their own on the setup.
The windy seems pretty good because its all in one, will I need the scart cable or anything else? I plan on hooking it up to a crt with rca cables if possible.
My cps3 is also a bit of a weird one because it doesn't need a cd to play the game. The person I bought it off said they owned a number of cps3's back in the day and the no cd ones were much more reliable. I didn't know it was possible to have a cps3 with no cd unless it was modded but this seems to be stock.
I'm also a bit worried that the version of 3rd strike on it will be the B version and I'll need to put the A version on for tournaments, how will I be able to do this without a CD? Also would I be able to get the Darksoft bios I keep hearing about with a no cd version?
How can I tell where the cps3 was manufactured? I know there's a usa, japanese and asian version. I'll attach some photos below if that helps.
Finally, whereabouts could I get an enclosure either for everything or at least the cps3. Any diy ones anybody has made? I just have the board without the metal casing I've seen some cps3's have.
Thank you so much for the help!
