Hackcell
Heredia, Costa Rica
Hello,
After quite some years, I was able to get the topper for my Daytona twin. It turns out, it does not have the fluorescent tube, but it has the fixture. It seems the original tube has a very weird (at least to me) length: between 31 and 32 inches.
Does anybody know if that's the correct size, and where to get a replacement? I've been looking in amazon and ebay for a led replacement and nothing related to this size.
Thanks!
I bought a 3ft integrated LED tube and called it a day.
I may have been able to reuse what was there, it’s been a while and I can’t recall. Either way, the tubes always come with small holders you can mount if necessary.
Wiring is pretty straightforward. There are two white wires, one ties to hot (black) and the other neutral (white). For the integrated tubes it doesn’t matter which is which. Then there’s a white wire with a yellow stripe that you run to ground. Thats it. You can splice it right to the connector that’s already in the header.
