cruzlink2
This is a board that was working up until a few weeks ago. My friend sent it my way to check, I did all the obvious stuff. Opened and cleaned the cart with rubber eraser and 99 percent isopropyl, cleaned the cart slot with a card wrapped with 2000 grit sandpaper and then same card wrapped with microfiber and isopropyl. I also took out all the Simms cleaned them and their respective slots, reflowed the pins on the slot for good measure. I tried another 2 known working darksoft carts on the board and tried the darksoft cart that came with the board on a working case and it loaded fine. When you power on the board does nothing, the SCSI2SD goes through it's paces. All you see when you first power on is a slight sync pulse on the ossc screen and then it goes away. I also had replacement cart slot and thinking that maybe the pins on the old one were too lose, went ahead and replaced it. Before ya all go saying that maybe I damaged something during the cart replacement, let me assure you I went with my meter in continuity and verified all pins. Just posting here to see if anyone has any suggestions, my next step would be to go and verify all the vias around the cart slot.
