l_oliveira
Let me put it in a plain way:
Dongle auth is different than PS2 MC auth so we can't access them through the serial side (normal connector it has on the edge).
To circumvent that there are two ways of accessing the nand:
1- Imaging it with a hardware chip programmer and use mymc to access the filesystem within the image.
2- move the dongle nand to a PS2 memory card (with both a PS2 or PS3-MCA can unlock) and have that to access the file system.
You already have hardware for trying method 1. I suggested you get some hardware (PS2 memory card and CECH-ZM1 USB adapter) so you could use method 2 which is slightly easier and less likely to have bugs as you have the memory card controller chip of the PS2 MC deal with the ECC algorithm.
