Ok update for today
black case mostly done.
all i need is gather the materials and pack boxes.
that means !
@nekojeeta - CPS1 SFII Hyper fighting
@blonu - CPS1 - SFII CE
@Smurph ----Both sega16 multi case (picture)
you all , i will prepare the orders next to make some space to work on the white cases
@LemmyBarnett ---- Shinobi
here's a picture, only need to prepare the white sega16 and yours will soon follow.
after that ill be ready to do all the remaining ones
BUT
A PROBLEM showed up. A small one.
every cases has this...-_-
i wont go into details on how it happened at work but someone messed up a bit on bendings.
The case's base and top still fit dont worry.. you can see on pictures
the problem is that they fit VERY tight.
You will all have to pry one side (left side or right side) so that the top fit on the base.
If you have to remove top after install just be careful that it won't scratch too badly.
