Sp33dFr34k
I am using it on a Samsung 4K TV via an OSSC myself.
nope, that's full size DIN, where the HAS has mini DINAnyone have any idea which cable from RetroGaming cable is compatible with HAS Supergun?
I am looking at one right now but not sure if this one is compatible
https://www.retrogamingcables.co.uk/combo-av-supergun-rgb-av-scart-cable-tv-lead-cord-for-sale
This won't work "out of the box" and would need to be re-wired. The female Scart connector is wired for input instead of output. The same story with the latter adapter, but even more complicated because it uses the sync stripper which is unnecessary for HAS or arcade boards in general.Something like this should work with it
https://www.retrogamingcables.co.uk...emeister-xrgb-mini-passive-converter-for-sale
https://www.retrogamingcables.co.uk...rgb-mini-converter-with-csync-lm1881-for-sale
Note: this one requires +5V for a LM1881 circuit
Yes, that one works for sure.Would this kit works then?
http://etim.net.au/shop/shop.php?crn=207&rn=544&action=show_detail
