darksofter
Hello Everyone,
I have a Astro City with Naomi 1, a compact flash to dimm setup all hooked up to a Capcom I/O powered by a PC PSU. How can I fit the Capcom I/O and the Naomi onto that wooden board and where would I put the PC PSU? Is there a way to wire the PC PSU into the same switch of the Candy Cab?
I would be glad to listen to your suggestions.
This is all the Naomi gear.
I also have a Sega I/O
There were long metal feet that mount the Capcom IO over the Naomi, discussion about them and models for 3D printed reproductions can be found here: https://www.arcade-projects.com/threads/capcom-io-tall-feet.17744/
I have my Naomi and Sega IO mounted side-by-side in my Blast. It's an uncomfortable squeeze with the JAMMA edge facing out, but better with it facing down. Not sure about a Capcom IO or the power supply in an Astro.
https://www.arcade-projects.com/threads/mounting-a-naomi-and-a-cps2-in-a-blast-city.22132/
Don’t. Get a 480p solution. Naomi looks like crap over 480i and the common JVS to JAMMA adds lag
Yeah you are probably so right.
Why can’t you fit a tri sync monitor into an Astro?
This is really good. I will look into this. Thank you for the help
