mthngn
France
Hi everybody
I have a pcb of Killer Instinct known for cpu issues that heats up fast. There is already a heatsink on it. But a lot of people put a noctua type fan. I wonder if the noctua should be "attached" to the heatsink or on the contrary you have to respect a certain distance
What's your opinion ?
Regards
any fan is more efficient at a slight distance because the body of the motor in the center obviously has no airflow.
this means you will only cool the outer edges of the heatsink and still have a hotspot in the center because of a lack of airflow.
Thank you for your answer.
Concretely, what distance do you recommend for a Noctua 60mm fan from the heatsink?
anything over a cm should fix the issue
or you could offset the fan to the side slightly so the blades pass over the center of the heatsink
What I did was change the aluminum heatsink for a copper one and install a 30mm fan, it looks great and it doesn't even get hot
how is the original held on, tape or epoxy?
the original was taped????
or the new one.
that wasnt my question,
i was asking how the factory heatsink was held on.
