clintkolodziej
Looking for some ideas on a Killer Instinct 2 board I picked up. I saw a post https://www.arcade-projects.com/threads/killer-instinct-pcb-issues.13175/ by @mugen_ketsueki that also seemed to have a weird static image, but it wasn't clear what the final resolution was - it looked like the CPU was replaced but I'm not sure if that was the fix or not. All other posts seem to mention some sort of scenario documented here: http://solid-orange.com/1758 but none of those fit with what I'm seeing as I don't get the blue boot progress screen at all, but there are signs of life such as the sound BONG and the indicator lights seem to be checking for sound/disk just fine. Any ideas would be welcome.
Background:
The board came to me with an original hard drive and the boot rom [U98] had a broken/missing window on it. When booted the disk drive started to spin up and I hear one BONG followed by the SOUND ACTIVE light coming on. The D. DRIVE ACTIVE light comes on without the drive, and stays off with the drive attached (it seems it may flicker initially then turn off, probably once it sees the drive is there). In all test scenarios I end up with a pink screen with colored dots (kind of like sprinkles on a delicious pink cupcake of death), and the position and color of the dots are always in the same locations. Pressing Test/Service doesn't seem to do anything either.
When I received it, I immediately thought the boot rom was bad due to the damage (it was). Replacing it with an Any-IDE rom didn't seem to help. I moved on to the disk drive, replacing it with a DiskOn Module (as documented here: https://www.arcade-projects.com/threads/ki2-dom-killer-instinct-2-disc-on-module.3259/), that didn't seem to make a difference either. I inspected the PCB for damage and didn't notice anything obvious. I also pressed on all the chips while it was running and didn't see a difference (I also tried during booting but you don't get a lot of time so we'll consider that incomplete). Just for a test I also removed the boot rom and hard drive in various configurations - no matter what I do I get the one bong and the PCSOD.
So basically I see signs of life with the single sound BONG and disk drive lights that seem to correctly check for the drive, but it doesn't appear it ever tries to read the boot rom or proceed past that.
I also took a look at the pins on the CPU, it did look like someone reflowed them as there is light flux residue around the chip. I pressed on each pin and none appear to be loose, and none appear to be bridged under 3x magnification. My multimeter's probes are too large to test each pin for continuity against the pcb pads or against the neighboring pins so I'm stuck there until I get a better multimeter. I'll probably get out the logic probe next to check chip activity, notably the RAM to see if there is anything I can notice on those, and on the boot rom and socket (especially since the original boot rom was damaged).
Any other ideas let me know. It could be the CPU but I figured I'd ask since I don't seem to see the white lines screen like everyone with a bad CPU seems to mention -- also it isn't clear if those with CPU problems get any activity at all, like the BONG or disk lights, so maybe I lucked out there? The CPU heatsink gets hot after a minute or two, but not too hot to touch and everyone always says it normally gets really hot so that may be normal.
Original Test:
Configuration:
Original hard drive
Broken boot rom [U98] - verified NO MATCH against MAME
Boot up result:
D. DRIVE ACTIVE: OFF
SOUND ACTIVE: OFF initially, turned ON after the bong
Screen: Pink screen with colored dots (always in the same place)
No Boot Rom Test:
Configuration:
Original hard drive
Boot rom [U98] removed (empty socket)
Boot up result:
No Hard Drive Test:
Configuration:
No Hard Drive connected
Boot up result:
D. DRIVE ACTIVE: ON
No Boot Rom / No Hard Drive Test:
Configuration:
Boot up result:
D. DRIVE ACTIVE: ON
New Boot Rom (U98 Any-IDE Boot ROM L1.4) Test:
Configuration:
Original hard drive
Replaced boot rom [U98] with a working ST M27C4001-10F1 using the U98 Any-IDE Boot ROM L1.4 from Killer Instinct Project
Boot up result:
New Boot Rom (U98 Any-IDE Boot ROM L1.4) / New DiskOn Module Test:
Configuration:
Replaced original disk with a new DiskOn Module with the KI2 CHD written to it
Boot up result:
Background:
Original Test:
Configuration:
Original hard drive
Boot up result:
No Boot Rom Test:
Configuration:
Original hard drive
Boot up result:
No Hard Drive Test:
Configuration:
Boot up result:
D. DRIVE ACTIVE: ON
Configuration:
Boot up result:
D. DRIVE ACTIVE: ON
Configuration:
Original hard drive
Boot up result:
Configuration:
Boot up result:
