Raph_friend
I saw a post saying to go into dip switches in the menu to fix this. It doesn't even run on mine :/.Ghost 'n goblins runs, but is now upside down.
Can you attach your mister.ini? Are you using hdmi out or vga?I cannot get any of the Jotego arcade cores working to save my life. CPS1 cores boot up, but either nothing happens or I get scrambled black and white bars. CPS0 etc all claim some file's missing in the game's zip.
I apparently don't have one? Just searched the SD card and I only have Mister_example.iniCan you attach your mister.ini? Are you using hdmi out or vga?
Gotcha, that should simplify things then. Mister.ini is optional, Jotego just fixed a bug with the scandouber.I apparently don't have one? Just searched the SD card and I only have Mister_example.iniCan you attach your mister.ini? Are you using hdmi out or vga?
HDMI out for now, figured why complicate things while I'm still getting it setup.
No, the one I'm using is called update_jotego.sh . I believe it came with the Smokemonster packs I downloaded this weekend.Onto your issue...are you using github.com/jotego/jtbin/tree/master/mister/update to update?
It just reports "Nothing to update" on everything.Onto your issue...are you using github.com/jotego/jtbin/tree/master/mister/update to update?
Sure did. And manually downloaded the CPS1 MRA and RBF files.From Jotego's post in Patreon "You can get the cores via the update script but you need to manually download the attached MRA files." did you do that?
Good luck!Just set up my sd card will give it a first try tonite and report back
Correct, except I have jtcps1_20200502.rbfOk, lets confirm some folder/file structure:
/media/fat/_CPS1/cores/ should have file jtcps1_20200501.rbf only
/media/fat/_CPS1/mame/should have all your sweet rom zips
/media/fat/_CPS1/ should have all the *mra files
Odd, and all your other cores work correctly?Correct, except I have jtcps1_20200502.rbfOk, lets confirm some folder/file structure:
It boots into CPS1 cores, shows a black screen or junk, the little button mapping shows up in the upper left corner, and I have access to the core's options in the menu. But no sound or game video.
Everything in _Arcade throws an error for some file or another in the rom.Odd, and all your other cores work correctly?
