9999 Damage
Fixed. Firmware 2.1.45 addresses this. It's in the unstable/testing channels, but you can also install it manually through the web GUI. I installed it and can confirm I'm not getting that damn Wi-Fi wizard pop-up anymore. Of course, now I can neither find the setup wizard SSID from my phone, nor see the DCDigital attached to my LAN from the access point, so hopefully it will reconnect to my LAN when I get it out of the Vewlix Faraday cage.Dan confirmed that it's due to Wi-Fi disconnects "or no maple bus controller is connected," and said they'll create an option not to display that message. Of course, there will still need to be a way to invoke the setup wizard if it disconnects, and hopefully it won't always reset Wi-Fi settings every time it loses a connection.
I was surprised to see so much dithering now that I have a crystal-clear display. At first, I thought something was wrong, like low color depth or high sharpness, but I can see with a Google search that a lot of people have this shock when they first see a Dreamcast/Naomi shown clearly on a flat panel.
