I have an issue again i have Tekken 3 PCB and if i use the VGA connection with the scaler i get moving picture if i use the jamma connection and the jammafier i get dark and more or less stable picture but then i cant use the jvs usb connection. Any idea whats wrong?
Tekken 3 has fooled me more than once with the scaler :) You need to set it up to progressive scan, and also set the red/green/blue levels. Mine is often washed out white until I adjust it when I haven't been using it for some time.
Luckily its not washed out and looks really good with 240p only issue is the board sometimes does not boot after the good morning voice 🤣 which makes no sense since ot does not need to warm up to boot just trying it again solves it.
Tekken 3 is interlaced or progressive 15khz. You can select it in the test menu as well as separate or composite sync.
