RandomRetro
That is for PAL F. PAL G should just be a straight plug it in... or at least I thought.Shouldn't there be a pin lifted on the G-Pal?
I used a Pal G on mine and I had to lift pin 9. It has been a while. I think it depends on the B board revision.That is for PAL F. PAL G should just be a straight plug it in... or at least I thought.Shouldn't there be a pin lifted on the G-Pal?
Roger.He has Rev 7. There is no need to remove the pin and that would only affect sound and graphics. It wouldn't prevent it from booting
Maybe you are getting poor connection to dip sockets due to corrosion/dirt. I would try removing the multi and spraying all of the dip sockets with DeoxIT D5, then try installing it again and see how it goes.So humbly eating crow here... but posting in hopes I save someone else form the humiliation My issue was the fact that the multi connection bridge wasn't pressed down fully. I thought I was going to break the board, but nope. Here is a picture to show what it looks like fully pressed down...
But I guess my issues aren't fully resolved. Things seem to be booting inconsistently with errors. Sometime I rewrite the image and all is good, other times I get a solid color screen, boots to unresponsive test menu, boot with graphical glitches, boots and stays on one of the start up screens, etc... I tested and adjusted the voltage on the PCB jamma edge between 5.0 - 5.1v and the same issues persist. The varying boots occur with the same game, so it isn't game related. My only thought is related to power. I am testing this on my HAS v4 with Mean Well 606 PSU, and I have reseated my B-board several times.
Any other suggestions, or retire?
Thanks, Im very happy with it.Enjoy!
Forgot to mention, I encounter no sound from my supergun while using the HDMI connection. I just used the cps2 b board rca jack with 12V powered speaker for sound.Hi @debemus
You will probably find the sound is fine on the other A board but the volume needs to be reset. Hold down volume down while powering on to do that
