Hey all,
I know I posted a very similar thread some time ago, but this is a separate issue.
Basically the right/player 2 gun has some tracking issues where the cursor will randomly skip all around the screen. Calibration does not assist with the issue, and it doesn't happen all the time. But when it does happen it happens for a random amount of time, then seems to go back to functional.
I've already replaced the sensor board on the gun (dang those are expensive) and the behavior is the same as before. I've also opened the gun itself and inspected all wires and connections several times and everything appears to be in order.
The left/player 1 gun operates completely fine 100% of the time.
I've opened the cabinet up as much as I dare to inspect the various components, but my amateur inspection doesn't see anything obvious. Any suggestions where I might inspect closer and what to look for? And again, just to clarify, the issue does not happen 100% of the time, but it does have quite often (several times per play).
Thank you!
Thank you!
