Hi there,
It's been awhile since I've posted a JAMMA modification project, but here it is
I recently got the wonderful After Burner arcade PCB. I was aiming for the entire arcade cabin but could not get it.
Regardles, I've made a JAMMA harness that will allow you to play After Burner on your Supergun.
I will have to say that you will need a potentiometer based controller to play with it as it requires a 5K ohm potentiometers to allow control of the jet.
I bought a 5K ohm joystick from ebay : https://www.ebay.com/itm/Joystick-P...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649, and got into a carft project with my daughter in designing the case for it (made from cartboard).
The filterboard (which i got along with the PCB has 3 connection ports that will be used:
For wiring connections, I'm using the Du-Pont connetcor crimps for a solderless environment, and they are working great.
Check the attachments for the picture of the filter board connetctions, and charts for wiring and the controller.
Feel free to ask questions
- 20P - for sound, video and steering
- 10P - for powering the PCB
- 25P - for additional controls
