freddiefiasco
After playing on my MT3 cabinet, my PSU finally died. I tested voltage on the following lines:
DC Outputs:
+12V: Reads 3.844V
+3.3V: Reads 0.266-0.277V
+5V: Reads 0.000V
AC Output:
120V: Reads 121.8V
PSU: VG88-11121-01
The PSU houses two potentiometers (+3.3V/+5V) on the back side where the power cables are attached to the PSU case. I had them at the correct voltages before death so I may hesitate to adjust this knowing the voltage readings are so low.
My next steps are to open up the case and clean out the dust and years of use.
After that, I want to say I need to replace the capacitors.
Are there other checks I should be doing before making an inventory of the capacitors to replace in this PSU?
I know the simple answer would be to replace this with a new one (New ones are between $114 and $144 online) but I think I would like to make this journey to resurrect this PSU if at all possible.
Given the risks, I would also make sure to be careful dealing with this repair.
Edit: Fan on the PSU never worked but I assumed it only kicked in when necessary but I don't think this PSU is that fancy.
DC Outputs:
+12V: Reads 3.844V
+5V: Reads 0.000V
AC Output:
120V: Reads 121.8V
PSU: VG88-11121-01
