neurokinetik
I am working on a DDSOM board set for a friend. It is a South America version. This was a board he got as part of a "mixed lot" of CPS2 boards. The board had the battery replaced before I got my hands on it, and it also looks like the jumpers were changed. I have never gotten anything out of it but a blank blue-green screen.
Here is what I know:
Things I have tried:
Nothing I have done has given me a different result.
In addition, I've had no success in even burning any ROMs for the different versions of this game. For example, trying the pheonix ROMs (DDSOMUD set from Emu Paradise), I can't get ROM 3 to burn (Write failed, Address=0x000002, Buffer=0x66 Device=0xFF). I always do a blank check before burning, and a verify after, and have been erasing using the UV eraser.
I am using a GQ-4x4 burner with an external power supply. It passes all of the diagnostics. For the HN27C4096G EPROMs, I am using the adapter as required. The adapter is not required for the HN27C101AG ROMs.
Do I need to use a different file format (default is .bin, options are ) Read Mode (default is Normal - but have options of Even Byte, Odd Byte, 1st Byte of 4, 2nd Byte of 4, 3rd Byte of 4) Fill Mode (default is Normal - options are Fill 'FF' or Fill '00')?
Is there anything I am missing here?
- I found the correct jumper settings and corrected them. It has an F-PAL, which is correct for this board set.
- It has the original mask ROMs in place for positions 11-20.
- The EPROMs in positions 3-10 were a mixed bag of various manufacturers. I have enough Hitachi HN27C4096G-12 to replace all of them. The sound ROMs were Sony CXK27C1000DQ-15. I burned Hitachi HN27C101AG-12 to replace them, as my burner does not have a listing for the Sony devices and I wasn't 100% certain that using one of the substitute chip settings was working properly.
- The A board is filthy, but I at least get the fan spinning when I power it up. The B Board case looks like somebody used it as a hockey puck, but internally it looks ok.
- No bent or missing pins on the board interconnections.
- Obtained the MAME ROMS for DDSOMH and burned a full set. They all verified successfully once burned.
- Performed the de-suicide procedure.
- Tried Razoola's suicide check ROM in position3 with the battery disconnected and the capacitor discharged.
