Is there a walkthrough for this somewhere? I see tons of stuff on make CF cards but nothing on making SSD's for the triforce. I just updated to the 3.12 firmware and am netbooting fine but want to make a SSD.
Thanks!
Thanks!
After you talked about having to make a cf card, then change the ssd id# and clone the cf card to the drive, it started to sound like a ton of work so I just decided to go cf only and gave up on the ssd until I have more time to sit down and really dig into it.You know that the CF and the SSD will certainly have different IDs, right?
I thought they were both the same for the triforce and it was the Naomi that had two different ones. Im almost positive on my other setup with Mario kart and a ssd kit I got from darksoft that I used that pic to netboot along with doing the ssd but I could be wrong. Ill have to defer to Mitsurugi on that one cause I bought the pics from him a couple of weeks ago.your using a netboot pic for cf booting?
Using this ide to cf reader for my computer (this reads the card and gets the id fine but gives me a can not write error when I try to use naomicf, I read this was due to windows7?)Pics of your setup?
I will double check this tonight, but im almost 100 percent positive dip 1 is set to on and dip 2 is set to off, I believe if it wasn't the trifoce would just come up and say "checking network" and not even look for the gd rom driveHave you checked dipswitch, back to CF mode after netboot the firmware?
