Just picked up a taito f3 board with puzzle bobble 4. Japan region but i dont think that should matter. I get sound but no video. Tried pressing the sw1 waiting press stick down 5 times the player 1 button. It reboots but same things. Any ideas?
Weird. Do you have an arcade cab and a supergun, by chance? I'd try testing it in both, if you can.saw that post. Ran it at 5.10 and even bumped it uo a little more to 5.15. Still no video just sound works.
The only thing that I ever used that worked with the F3 was a SCART to HDMI converter. Also works with PGM.thru my supergun and the gonbes cga to vga converter which has worked w everything i have tried on it from mvs, cps2 and many others.
I dont have a cab other than the one i built which also has a cga to vga converter.
A higher wattage version of the one inside the power supply. I use 1/2 watt.Makes me think of a second wuestion. What rating pot should i get to run an external 5v adjuster from the power supply?
