New Generation Metal Shell For Dreamcast
    • hursit wrote:
      I dont have the MODE hardware now and i couldnt test it. But it looks lik MODE will not fit into my case because of the my power switch. When i have started to this projects, MODE wasnt exist . I havent test it with my PSU
      I can totally tell you my PSU better than DreamPSU. That PSU has problems.
      I didnt test about RE-painting actually. But it looks like you can do it
      Thanks for answering those questions. It’s tricky eyeballing the MODE publicity images versus your images and trying to work out if anything conflicts. Perhaps I’d buy it and just use it with GDEMU if the MODE doesn’t fit when it arrives. I understand it wasn’t a thing when you designed the case. Maybe a toggle switch could be used in the disc change button hole or enlarge that hole to accept existing power switch If using MODE since that will not be needed in this scenario.
      I don’t suppose you have any unpainted plastic pieces that you’d be prepared to substitute on request so I could paint safely? I don’t really want to have to try and remove the paint or worry it’ll react if I paint over the top.
      glad to hear you’ve put more thought into your power supply than DreamPSU. If it still supplies 12v I would think it would have enough to power MODE in different configurations (still not a lot known about MODE from a technical perspective).
      The post was edited 1 time, last by dantethascrub: Addition ().
    • New
      Just got mine! Will be moving everything over into it this evening.
      Arcade MultiSystems:
      Sega: ST-V (Darksoft), Naomi 2 w/Net Dimm,Capcom CPS2 (Darksoft) , Capcom CPS3 (Darksoft), Neo Geo MV-1B (Darksoft), Sega C2 (Apocalypse), Taito F3 (Darksoft), Neo Geo AES (Darksoft), M72 Multi (Apocalypse)
      VAPS Profile arcade-museum.com/members/member_detail.php?member_id=481863
    • New
      I got mines today!! ^^ <3
      Gonna show pictures next week when i put it together.
      Images
      Thanks
      KingSopz :evil:
    • New
      @hursit - great quality on the unit!!! Went together very easily..... tested out 480p via component to CRT - works beautifully. I of course had the wrong 4x10 Noctua fan (got a 12v) so just ordered a 5v one.
      I am having some strange issue with my DCHDMI though - the video keeps freezing up - will be curious if anyone experiences this.
      *edit* I am back on my CRT - and still having intermittent freezing issues - will continue to test.
      Matt
      The post was edited 1 time, last by mathewbeall ().
    • New
      Ok - more info on this - been through a bunch of steps to try and figure out what is going on. When the system freezes - the orange LED lights up on the GDEMU. according to the website - that is what this means: "There is a status LED on the GDEMU, it should blink once during power-up and then remain off. If the LED is lit, or starts blinking during gameplay, an internal error has occured. There are many possible causes of that, including SD card data transfer errors. "
      I have tried.
      not using the SD extender - just having the SD card in the GDEMU
      removing the reset switch wires
      taking out my ethernet card
      my next step will be to put the dreamcast back in its original case to see if the problem persists - i know it didn't happen previously.
      Let me know if anyone runs into these issues?
      Matt
    • New
      I have tried.
      Matt
      Thanks for your testing
      if i understand it correctly, there was no problem with your original Case + DCHDMI + GDEMU right ?
      if yes, you have only changed your PSU on this system. Please can you try it with your original PSU ?
      I know several times GDEMU frezes on my original Dreamcast too, but this one is strange issue
      Welcome to My Discord Server: discord.gg/VjA7sk6
      Talk about all arcade staff.... ;)
    • New
      Hi Folks - after doing a bunch of back and forth testing with hursit tonight - I am pretty sure it was my large SD card causing the issue (256MB). While this worked fine in my original dreamcast case, it didn't like it so much in the new case. I had a 3d printed shround around the GDEMU - so perhaps there was more shielding? And we all know how touchy GDEMU is about SD cards.
      I ended up using a 32GB card with just a few games on it to test - and everything worked flawlessly with the 32GB card.
      Thanks @hursit!!
      Matt
    • New
      Thanks @hursit!!
      Matt
      Thanks for your efforts.
      We test it every step on the new Case and Old original Case. Then we found the problem which was the SD Card.
      Thanks again...
    • New
      Another strange issue - I got my 5v Noctua today - and somehow my dreamcast doesn't like the sense wire - it keeps shutting down after getting through the bootup menu... swap to original fan - no issue.
      I guess I will keep the stock fan for now.
      Matt
    • New
      Matt
      Hello
      did you use the Resistor with that ?
      I dont remember how many OHM but you have to use Resistor with Noctua.
      I will check my records and inform you about it ;)
      Edit: Found it
    • New
      Aha! I didn't know this! Ok - let me do that... :)
      10m later - THAT did the trick! :)
