8bitforlife
Multi Boyz
Carson City Nevada
ok I got my chassis from @rewrite but it's not a 29e31s as I thought it's a sanwa pm1745 15hz/24hz only
This is going in my konami windy2.
Iv bern told by @radiantsvgun that the 2930 is a direct drop.
So could anyone make me an adapter to power and get vga to and from my windy2 and monitor. I'll pay.
What's the connector on the Sanwa? 15-pin AMP UP?
I need a remote board for a Sanwa PM1745. If yours is going spare I'd love to buy it.
this the connector
I got confirmation from the master grantspan the sanwa I have and 2930 use same power connector. Hes also sending me remote cable.
What I need now is an adapter to go to windy2 which is vga.
Just be careful - if it's a PM1745 and you connect VGA to it, you will blow up the chassis. VGA is 31k
The Cyber Lead is 15/24 and uses a DB15HD (VGA style) connector, but it has pins removed
yes I know that's why I need something made for windy2. I have a konami jvs to jamma. Still connect the rgb vga to it.
I'm just not very good at doing stuff like this
this the connector
Here's the pin out for it if anyone here wants to make an adapter for 8bitforlife:
https://imgur.com/a/fEyIKZw
wow thanks @nem
Been trying to find pinout on windy2 but can5
But if it helps someone this monitor I'm using has no 31hz
A 2930 nanao dsub/vga/DB15HD is a drop in replacement. (Just wouldn't add the 31hz stuff)
Windy2 gives power to chassis with a separate cable like this. Its same cable connector as 2930
