Home Arcade System
Tough to say :/ I still haven't received some crucial parts for the HAS as well as for the PSU covers (the power inlet thingy has long lead times). I will only re-open when I can offer the most popular stuff all at the same time. Hopefully soon :)
Fingers crossed for fats comeback :)
Reactions: RGB
Hiya!
Just wanted to post a question (or maybe a feature request?)
I'm absolutely loving my HAS v5. But, I noticed that the audio automatically cuts from the JAMMA edge if the 3.5 mm jack is in use. In many cases, the auto-shunt behavior is honestly nice. But, in some instances (like when recording direct play), this can be problematic, since using headphones or some other audio source on the 3.5 mm shunts the audio from the captured recording.
Is there a setting to disable JAMMA audio bypass on 3.5 mm detection? If not, would it be possible to add something like that to the firmware (at your convenience)?
Thanks again (for real, this thing is an incredible bit of kit- really lovely).
-Dillinger
Bought one of the Basic covers for the Mean Well supplies, and I like it a lot. However, it seems to have a few minor design issues, at least with the RT85A I have.
1) The center support bar is too tall by several millimeters. When fully installed, neither screw hole lines up and you have to tilt the cover to catch one or the other. Not ideal. I took a hobby saw and fixed this rather easily.
2) The included screws are too long. They thread in fine on the side, but they bottom out on the underside which prevents the PSU from sitting on the rubber feet. A slightly shorter screw will fix this.
The RT85A I have is a new one from Digi-Key, so I would assume its a reasonable current version. I have not tried this on any of the other Mean Well supplies.
Edit: Oops, forgot the image. I measured and it extends almost exactly 2mm from base to the edge of the integrated washer.
Thank you for your feedback.
1) I will adjust the center support bar so that the cover fits the newer models.
2) I can see the Basic Power Supply assembly instruction is missing one step - the chassis screw must be unscrewed, otherwise it will block the bottom screw. The instructions will be updated.
Hiya!
-Dillinger
Thank you for your kind words!
The audio jack has a physical switch inside, it isn't controlled via the firmware, and it cannot serve as a secondary audio output. It was designed to provide an alternative audio output path so that audio doesn't go inside the same cable as the video signal (to eliminate the cross-talk interference from the CSync signal).
@RGB, I have a question, and I might be doing something wrong. Awhile ago I set rapid fire level 6 on buttons 1 and 2. Now, I use the menu to change them to 0 (none) and hit save and exit via the menu button, but it reverts back to 6 for them both when I re-power the HAS. If I use the joystick start button, then it will save. Is this because when I first set the rapid fire I used the joystick to set the rapid fire, so now using the screen "save and exit" doesn't work? If so, is that something you want to change in the firmware or if not update in the instructions to be clear, or am I doing something wrong?
Do you exit the remapping config menu with the BACK or MENU button? To save the change in the EEPROM, you need to exit the remapping config menu with the MENU button. If you exit with BACK, it will be just a temporary change. The Save & Exit option won't save it, it's for everything else but the remapping and rapid-fire. This might need a change in the future as it seems confusing, but I wanted to give the option to have a temporary rapid-fire/layout setting for a one-off need.
Edit: had a brain fart. So you do exit it with the MENU button.. This is strange, let me check here.
Edit2: Works here. When you're in the remapping configuration menu, the red led light up. If you leave with the MENU button, the config is saved and available after the power cycle. If you leave with the BACK, it's just a temporary change, it won't be retained.
No, you are correct, I exit the rapid fire menu with the back button, but use the "save and exit" with the menu, witch of course you just explained doesn't work.
Got it, OK, I'll obviously be fine now, but yeah, an update to make it less confusing might help. Of course, I'm the only one who's mentioned it so far, so maybe it's just me!
Reactions: RGB
When I was planning this, I thought it would be just a little extra squizzed-in and that it would make sense - OK/MENU button = save, BACK = exit without saving. I mentioned this in the User Guide, but it's become quite extensive, so it's easy to miss :/
Yeah, that part makes sense, but the "save and exit" not saving it is what confused me. It's all good. We've been doing some PVM game testing/playing and the only other thing so far has be Taito F2 won't sync with the PVM, so I'm trying to figure that out. I had it working before, so I'm sure it's something to do with the settings on the HAS. The stupid F2 long boards suck too b/c none of my JAMMA extenders fit easily on it. Yours works, but I have to take the plexiglass off, which is a pain.
Oh well, as they say, 1st World Problems.
Hi @RGB, wondering its possible to move the power cable insert to either left or right side of the power supply while the on/off button stays where it is, that way we can use a right angle or left angle power cable and the cable goes behind the power supply to the power plug so that way we dnt see it and also dnt have high volt cable next to the on/off switch, just sharing my thoughts!
No way, this is a MUCH better design, but if you really want it out the side, let me show you this, one in stock!
but this has the on/off button on the side as well which defeats the whole purpose (atleast to me) as its still next to the power cable insert.
Yup, as Nem said, the power output and the switch are the same unit purchased separately and added to the 3D print. If you want it out the side, you have to take the button out the side too. Sorry my friend!
Here is the part:
The power inlet unit has a built-in switch, so moving just the cable receptacle is impossible. Check out how this thing is built:
